0 members (),
239
36
Topics49,904
Posts838,088
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Thanks Tim. The battery earth looks fine which is why I'm surprised I'm seeing no life at the dashboard etc. That is strange - although I had a problem with the Renault 4CV (SpannerJuggler might remember) where I had a starting problem, and discounted the earth strap because it looked fine and the connections were clean and tight. I replaced it anyway on Colin's advice, and lo and behold, problem solved. The issue AIUI with braided earth straps is that over the years grease and oil gets in amongst the braids, raising the resistance of the strap.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The only way to eliminate the leads is replacement or a multimeter check, or even a test circuit. On one of my MG Metro's (note I had more than one!) - the earth lead to the gearbox bellhousing was critical. It also went to the battery. The tiniest mis-position, or the tiniest variation in torque on the bolt and the electrics were dead.
Posts: 29 |
Many thanks to everyone for their help and advice. After fitting new battery and cleaning and tightening earth straps car is running like a dream. Kind regards. Phil
Excellent news. Well done, Phil.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
+1!
Posts: 37,484 Likes: 989
Posts: 37,484 Likes: 989 |
+2 Great to hear you fixed it and back up and running  .
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Well done! Now you can jump into the car and no worries about starting.......added enjoyment!
Posts: 29 |
Took it out for a run this morning while the sun was out and the roads dry. Awesome!
