2 members (John V6, Moggo),
320
Topics49,915
Posts838,215
Posts: 6,538 |
A quick buzz down a local dual carriageway to see if my steering damper has done the trick. It does what it says on the tin....damps. Makes the car nicer to drive unless I'm up above 85-90.......the underlying fault is still there....which bugs me. Oh dear Nero! You're in danger of the order pad being scratched! Now what about that nice 4/4 80th anniversary model... You can almost feel it coming on!! But would be a great choice!
Neil
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
When I got back to Cranfield, Phil was doing some final preparation on a 1998 4.6 +8 that is being collected tomorrow. It looked fabulous - luck new owner. The great shame is that it only has 8000 miles on it in 18 years - I wonder what went wrong for the last owner. By comparison, our car has done 8150 ish miles in 2 years - not a great deal in comparison to some on here. And the new owner, who used to have a 4.6 but changed to a +4 a year or so ago will be collecting it. He is on here (occasionally)...  Misses the V8 grunt (and sound I'll wager!). I wonder if he lives in Aldridge? It looks a lovely car.
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
Quick HR drive to charge the battery & give her(Morgan) a breather. Slight panick as both front brakes locked on. Clutch took a hammering & reversed out of the garage with l/h solid just sliding along. So rented garage now got a long black skid. Got it to free by rocking between 1st & Rev aggressively. Syncro on reverse a help. Took some while riding the brakes & some hard stops to clear the brake "kick". Thought I'd put her away with dry brakes, but obviously not. Anyone got a solution for this phenomena? Bob
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
A bit stable door but I never park in the garage with the brakes on. Chocks may be used if required, or leave in gear.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
If there's a hint of parking up when wet or potentially salty, a hose down before putting away dry and as Bob has said, simply leave in gear.
Another reason to use it more, really..!
Brakes were off it was just the fronts locked. Been sat for 3 weeks. As I said thought they were dry. So just wondering if it is just damp causing the problem. Garage is dry but the desicater bag of crystals were quite wet.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Brakes were off it was just the fronts locked. Been sat for 3 weeks. As I said thought they were dry. So just wondering if it is just damp causing the problem. Garage is dry but the desicater bag of crystals were quite wet. you left your Morgan unused for 3 weeks !!! UNBELIEVABLE
Posts: 14,009 |
My fronts lock up on the pads sometimes...release with a huge bang!
Posts: 138 |
Had a run out to The Frog @ Skirmett for lunch, called in to the Chiltern Valley Winery & Brewery on the way back. Cracking day, listening to the birds I'd better clean out the nest boxes tomorrow!
1990 +8 Connaught Green 1970 Lotus Elan S4 SE 1973 Lotus Europa TC/Special
Posts: 49 |
Three weeks? With the prevailing weather, I'd need an amphibian MOG! Reading this, I just realised that I last went out in SEPTEMBER! That's a lot of polishing per mile! 😳
Dum Spiro Spero
