Topics49,902
Posts838,049
Posts: 681 |
Yes, I was initially startled by the Chinese characters on my e-receipt (phishing, or what?) but then realised the source of the units. Your endorsement is worth a lot  , thanks again!
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Guys, disconnecting the battery used to work with older technology (prior to Bosch LH2.2) which was the first mainstream 'adaptive' ECU. It introduced E2PROMS to motor manufacturers and where before an EPROM can be reset by disconnecting the supply voltage an E2 (written as EEPROM for Electronically Erasable) is as the name suggests a PROM that has to be electronically overwritten. Disconnecting the feed on later systems may well put the light out but will not delete any stored fault codes or in fact reset the system. The adaptive function has both long and short term adaptivity (trim) and it's just the short term that reverts to manufacturers map settings....the long term fuel trim needs to have the code read and then reset (assuming there is just a rogue code or the problem has been fixed) to set the system back to standard again. This is true for the Ford EEC family of ECU's as for other manufacturers. When these later systems were first iintroduced we (Volvo) were inundated with customer complaints where MIL lights were coming on, cars were taken to dealers, the battery disconnected and the car handed back only to have the light come on again shortly after, this was because there was an actual fault and the car had not been fixed and the ECU had only been partly reset. Just for info chaps, lots of information on websites on this if you want further reading but also why I suggested getting a cheap code reader, for around the cost of 3 gallons of fuel its worth having in the car, takes less than 5 min to reset! Colin I was given a stark choice by the factory. They could stop the incessant pinking that my car exhibited (a known issue on some early Duratecs ) only by doctoring my ecu. However the down side would be that I would lose my diagnostic functionality. As it’s a fairly uncomplicated engine I went for that option, I couldn’t live with the pinking. Resetting the ecu with a battery disconnect is my only option now. My ecu also appears not to be able to be re mapped. That’s why I’m searching for a new ECU (if anybody has any alternative suggestions I would be very grateful).
Roger 2011 Plus 4
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Logs are stored in none volatile ram that's why they don't vanish in latter ecu's but getting rid of an engine lamp via a power reset if you don't have a code reader gives you an idea if it is a transient fault or a permanent fault ie more serious
It'll be interesting to see if I get any codes after being away from my mog for a while ie where petrol has dropped it's potency for instance causing knock etc.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I bought an Autel code reader a while ago. I occasionally get the MIL light on and it tells me what the problem is and allows resets. So far the fault has been "random intermittent misfire" or, once, " evap system". My Autel is a non current model and not able to have software updates but covers most makes up to about 4 years ago so the Plus8 is in safe hands, using Rover or Landrover as selected make from the menu. I tend to carry it in the car on weekend/ long runs for peace of mind checks if needed. It is simple to use. It also has many modes/ stores/ outputs as well as simple diagnostic/reset ability. It paid for itself on its first use.....about £40 on ebay. Last time used it took only 2-3 mins to check and reset the "misfire fault" and was done at a coffee stop on a run.
