0 members (), 339 guests, and 23 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Page 3 of 3 1 2 3
SBM Offline
Ha! I can't believe two grown men are talking to each other with little pictures..
Ah, yes, grown physically, but yet to achieve full mental maturity [according to my wife anyway].
I think there is a bit of "tolerance" in the build of the earlier cars chassis in particular. I originally installed the Empire kit on my 2013 (chassis number 799) and adjusted to 1.5 degrees negative camber without any problem. Both sides were not adjusted exactly the same so there was a small lack of symmetry in the chassis. Following a chassis change late last year, to a 2015 spec, I had to cut about 4 mm off the threaded end of the Empire upper wishbones to get close to 1.5 degrees on full adjustment. There is plenty of metal there for this. Both sides are about the same adjustment on the new chassis. The Empire kit was built for Pauls pre 2014 M3W and it seems not all of the chassis are (or were) exactly the same.
Got a sign above my workbench says "Never to late to start a second childhood" Never mind second, I'm way past that----
Page 3 of 3 1 2 3
