7 members (RichardV6, RedThree, cerealsurfer, simon8201, Dek, AlyMatt, itsfrank666), 334 guests, and 37 robots.
+8Rich 91
John V6 49
Posts837,985
Page 9 of 11 1 2 7 8 9 10 11
Per the MSCC mag the cyclops light is just for the show car... the production version will have 2 "in the cowl"....
Thats great news - thank God for that!!!
Why not have the Twin lights on the Show car?? The Cyclops look may put some off!
Neil
Originally Posted By spelunx
Petrolicous just posted another short article about this car Morgan's Electric 3 Wheeler
Nice article.
cooooool!
There was only one in the Spares department.
The cyclops presentation is a great marketing gag.
Who would talk about a funny electro cyclecar but lots will comment a strange cyclops
Morgan is maybe not the best in quality and customer service when it comes to 3wheelers but great in marketing.
Finally there will be mudguards, indicators, double headlights and all other stuff anyway
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
rofl
Neil
What use is a range of 150 miles?
It means that you cannot travel further than within a radius of 75 miles from home unless you can be sure there will be a convenient charging point on route.
Living 140 miles from Malvern, this means that I could not even visit the factory (if I so desired), unless I could fully recharge whilst I was there.
If I was to own one of these, I would be constantly looking at the odometer (or the "state of charge" meter, assuming it has one) and worrying that I may not find a charging point before the batteries go flat, which would obviously result in being stranded, possibly miles from anywhere.
How many AAA batteries would it need to limp to the nearest garage/charging point?
I can see it all now, a EV3 with a trailer behind and on that trailer is a gas generator. Stop and take a pee brake at the same time fire up the dynamo and plug in the cord and magically you have another 50 miles of go juice...
Dan
Just toss one up on the luggage rack!
kirkusblog.com
1952 Ford 8N
Online NoMood
I agree and worse is that typically a batteries capacity after peaking during the first few charge/discharge cycles, then starts a slow downhill run on capacity. That 75 mile safe radius is going to diminish.
I'm not sure if its relevant to the batteries used on the EV3, but I remember reading that whilst Li-on battery technology was discovered nearly a hundred years ago, it wasn't until the 90's that the neccessary charge control technology was perfected. The main issue with this type is charge instability. Careful monitoring is required especially towards end of life when excess charge current could otherwise lead to heat build up and ultimately explosion. To prevent this internal circuitry may decide suddenly to shut battery down (brick it) forever.
