10 members (Arwyn Williams, John Wilcox, AlyMatt, Plus Four Guy, jbk, Sir Percival, TalkMorgan, JohnHarris, Saxman1964, gomog), 218 guests, and 35 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
#347443 14/03/16 01:26 AM
Marcus Offline OP
It would appear as if the headers on my '70 4/4 Kent Crossflow engine were at one time chrome plated. They appear to be a 300 series stainless of some sort since they are not magnetic. They are completely discolored. I'd like to blast clean them and then paint them a satin black of some sort using hi temp paint. They will certainly look better than they do now. If in fact they were chromed originally I might just bite the bullet and try to find a shop to re-chrome if the price was right although they would discolor again I suppose. Can anyone verify if these were usually chrome or were they black?
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
1988 Porsche Boxster
Marcus #347468 14/03/16 07:35 AM
I can't imagine Mr Morgan flashing the cash for chrome.
Marcus #347469 14/03/16 07:43 AM
I very much doubt if it's chome applied on to stainless steel.
Stainless manifolds stain, particularly in the area closest to the cylinder head where the exhaust gasses are hottest.
You could try polishing it out or simply admire life's chemistry and metallurgy at work! If it works, why worry?
Marcus #347514 14/03/16 10:20 AM
Marcus Offline OP
Thanks for the input. I think I'll just clean them and let it go at that.
Mark
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
Marcus #347790 14/03/16 09:39 PM
I just use rattle can exhaust paint. When they get unsightly, wire brush them and paint them again. Not sure but these headers are hard to find. Try to keep them from rusting.
Button
Seattle
Button
Marcus #348030 15/03/16 06:57 PM
If they are stainless, why not try using a fine abrasive paper on a small section and see what happens. I recently had some s/s manifold pipes to clean up, and tried this, which worked fine, but I wanted a highly polished finish, as they are on show, so took them to a local exhaust fabricator who polished them on his wheel, they looked a treat too, but a couple of thousand miles down the road, they are right back to where they were before. I've come to the conclusion that you either just leave them or wrap them.
Marcus #348044 15/03/16 07:42 PM
The heat they have to cope with means they will keep on becoming blue/straw coloured.
When tempering steel these are the colours blacksmiths etc used to look for before quenching, indicating the correct temperature.
Some high temp paint might work but I am not sure of its durability.
