Topics49,911
Posts838,146
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Its down to a thread differential, heat will have no affect on it as the threads don't change with a heat cycle?? If you ever strip one of these rocker arms it all becomes apparent. In certain classes of Motorsport Roller Rockers are banned but other mods allowed so it was fairly common to see a Kent based unit getting up there in the rev range and as others have said never ever seen one come loose. At one stage I had a Mk1 Escort big wing and we were running an Oselli Engineering 1300cc, that pulled 7,500 and 8,000 when I was dropping time, never had a valve issue.
Have added a few rocker arm pictures to the Gallery
Posts: 8 |
Does anyone use the "Rule of Nines?" Back in the 60s I used to adjust tappets this way . When #2 valve is fully open , adjust #7.. When #1 is open, adjust #8......and so on as long as the pairs add up to nine. This has always worked for me although it seems like magic ....Terry
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Think it still works on a 4.
Posts: 1,943 |
Works for Me on My 1963 +4-4Str.
Button Seattle
Button
