Topics49,901
Posts838,043
Posts: 62 |
What is the generally accepted temperature rating for a thermostat in a '70 4/4 with a Kent 1600 crossflow engine. I want to replace mine but I can't find any rating on it. I don't drive it in the cold weather so I'm not worried about getting heat quickly. Also, what is the pressure rating for the radiator cap. Thanks,
Mark
Mark 1970 4/4 Morgan Two '53 MG TD's 1949 MG TC 1988 Porsche Boxster
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Mine is 88 deg C if I recall correctly.
Richard 1976 4/4 4 Seater
Posts: 1,947 |
According to lore, you gain a bit of power with a slightly lower rated thermostat on that engine.
Posts: 381 |
If your thermostat is still working, check the opening temperature. Put it in a pot with water, heat it and check the temperature at the valve opening using a kitchen thermometer or an infrared forehead thermometer.
Regards 2005 PLUS 4
