5 members (John V6, Chris Cosher, jbk, RichardV6, bmgermany), 311 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
#349155 20/03/16 01:22 AM
Marcus Offline OP
What is the generally accepted temperature rating for a thermostat in a '70 4/4 with a Kent 1600 crossflow engine. I want to replace mine but I can't find any rating on it. I don't drive it in the cold weather so I'm not worried about getting heat quickly. Also, what is the pressure rating for the radiator cap. Thanks,
Mark
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
1988 Porsche Boxster
Mine is 88 deg C if I recall correctly.
According to lore, you gain a bit of power with a slightly lower rated thermostat on that engine.
CBY Offline
If your thermostat is still working, check the opening temperature. Put it in a pot with water, heat it and check the temperature at the valve opening using a kitchen thermometer or an infrared forehead thermometer.
Regards
2005 PLUS 4
