3 members (JohnHarris, Mike D, Montegue), 301 guests, and 40 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,044
#350706 26/03/16 01:10 PM
vMog Offline OP
Hello,
As I was driving to Blenheim on a beautiful day yesterday, I noticed something I had never seen before on my oil gauge: the dial, which usually sit somewhere around 3 bars, would sometimes go up to the 5-6 range. I checked the oil level and it seems ok.
How should I interpret this? sherlock
Is there anything wrong with this? confused2
Need I worry? scared
Kind regards,
Vladimir
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
Several possibilities.
It may be a sticking oil pressure relief valve.
Did your other gauges move also? If so, it's more likely to be a bad connection (usually earth) behind the dash...
Mine when cold is around the 5-6 mark when it has warmed up properly around about the 3 bar on the move, when sat still on tick over I notice it drops to about 1 and a half bar
Mark - No Longer driving
My 2008 +4 does this all the time, normally for just a minute or two, I was told by a dealer it's not uncommon and can be considered as an electrical resistance issue, in other words not a problem.
BR Colin
Mine reads the same Mark, again dealer advised as long as it's above 2 Bar when at 3,000 RPM it's fine.
BR Colin
I fitted a oil gauge in place of the clock that came as standard (have a Mig clock so don't need two) and it reads in PSI.. around 95-100 cold and 30-40 ish idle.. not sure what that is in Bars..
1 Bar is 14.504 PSI
BR Colin
SBM Offline
Mars Bars are different.. innocent
So a bit higher, may not be totally accurate I guess or the gdi is different..
A Mars a day Steve
My 1 bar is The Bull at Benenden
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
