2 members (Zach, DCH),
222
33
Topics49,911
Posts838,147
Posts: 430 Likes: 2
Posts: 430 Likes: 2 |
Hello, As I was driving to Blenheim on a beautiful day yesterday, I noticed something I had never seen before on my oil gauge: the dial, which usually sit somewhere around 3 bars, would sometimes go up to the 5-6 range. I checked the oil level and it seems ok. How should I interpret this? Is there anything wrong with this? Need I worry? Kind regards, Vladimir
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Several possibilities. It may be a sticking oil pressure relief valve. Did your other gauges move also? If so, it's more likely to be a bad connection (usually earth) behind the dash...
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Mine when cold is around the 5-6 mark when it has warmed up properly around about the 3 bar on the move, when sat still on tick over I notice it drops to about 1 and a half bar
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
My 2008 +4 does this all the time, normally for just a minute or two, I was told by a dealer it's not uncommon and can be considered as an electrical resistance issue, in other words not a problem.
Mine when cold is around the 5-6 mark when it has warmed up properly around about the 3 bar on the move, when sat still on tick over I notice it drops to about 1 and a half bar Mine reads the same Mark, again dealer advised as long as it's above 2 Bar when at 3,000 RPM it's fine.
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
I fitted a oil gauge in place of the clock that came as standard (have a Mig clock so don't need two) and it reads in PSI.. around 95-100 cold and 30-40 ish idle.. not sure what that is in Bars..
Steve 2008 4/4 1.8 Duratec
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Mars Bars are different..
So a bit higher, may not be totally accurate I guess or the gdi is different..
A Mars a day Steve
Posts: 853 |
My 1 bar is The Bull at Benenden
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
