1 members (GLLOQ),
209
32
Topics49,897
Posts838,018
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
I think the battery is on the way out, the volt meter now shows c 11.5 V when running & starting from warm is sluggish. It is I guess the original so 10 years old.
Any advice what to buy? Red top Optima's seems 3 times the going rate, are they worth it.
Posts: 490 |
There have been a number of posts recently on replacement batteries. A quick search should reveal all. My 2 penneth for what its worth is Odyssey. peter
"Hasta la victoria siempre"
Peter their site says there is no match in their product range
Posts: 347 |
I now only buy Varta batteries
2014 +4, Le Mans Blue / Magnolia "Meg" the Mog
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
When running the alternator should be giving 13-14 volts regardless of the condition of the battery. If it is faulty your battery may not be fully charging. The battery standing battery voltage should be about 12.5 volts and should not drop below 10 volts when the starter is cranked. Try charging the battery up with a charger and see how it performs.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
John, I'd have brought a test meter with me today had I known. I'd recommend checking directly at the battery - engine off and running. The fitted dash voltmeter can give erroneous readings as the take off point is not close to battery/alternator.
Posts: 1,943 |
Sounds like battery maybe OK. I would try charging the battery first.
Button Seattle
Button
The battery shows 12.9v across the terminals after charging on my ctek Will check when running next weekend when back from S E Asia
That's low. I presume it's a dry cell? Nominal lead acid for most of charge/discharge cycle should be 13.2V (2.2V per cell). When new('ish) at full charge you should see around 13.8V fully charged... HTH
Will order one to fit next weekend
