Posts837,978
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I'm a newcomer to this ritual...just bagged myself a Clark recommended grease gun with flexible thingy and a tube of the Red n Tacky stuff.. Well, it matches the paint innit..?
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I use degreaser and handspray to wash the springs. Brake cleaner to clean the discs afterwards. I have some ex Post Office goretex trousers( heavy duty) so need to use it for spring gaiters at some time. Bought from ebay a few yrs ago for gardening etc but rarely used. They are quite baggy so plenty of material! I use a pressure washer on cars but keep a decent distance away, using the lance for lower pressure. It forms a lovely "mist" from a distance for rinseing too.
SBM....how is the Red n Tacky performing?
Posts: 1,943 |
I spray every thing in sight (incl engine) with "Simple Green". (Strong Detergent). Let it sit overnight and spray again with SG. Use an electric 1600 PSI Pressure Sprayer and use it liberally. Engine, Diff and Front Suspension. I never thought of using chain oil on the rebounds, but sounds like a good idea and I will do so in the future. Of course chain oil on the rear leafs. I pick a warm/hot day as I am sloppy and get water everywhere. BTW: I do not keep My Morgans to Show Room standards. They are drivers and if the 20 foot test is OK that is good enough for Me.
Button Seattle
Button
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I had my Mog serviced by a very well known, well respected non franchised specialist, collected the car looking pristine. A couple of miles down the road following collection I noticed a wheel bearing rumble unheard before. Some days later I stripped down both front hubs to find they were full of water due to the pristine looking wires having been cleaned with a power washer forcing water beyond the hub seals. Both wheel bearings replaced on both wheels. I now do my own servicing !
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
I would never use a pressure washer on a morgan. More care is required.
Martin (Deano)
Posts: 286 |
The best reason to not use a pressure washer...and it hasn't been mentioned...is the force of the water can take the paint right off the coils. This exposes the bare metal to rust.
Don't do this.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
This is a very good point. My Stihl pressure washer has a couple of lances, one gives a concentrated blast that I wouldn't get anywhere near a car, the other is adjustable down to a fairly gentle spray, and by standing back the pressure is hardly anything. Like everything pressure washers can be very useful, but need to be used sensibly - and in my book using them at high pressure to blast grease and grit from the front suspension isn't one of them. YMMV, of course.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
And keep well away from the wing beading.
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
The only thing I use a pressure washer on is the wheelie bin
Roger 2011 Plus 4
Posts: 881 Likes: 31
Posts: 881 Likes: 31 |
Pressure washer usage anywhere near my B1800!.......
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
