Topics49,880
Posts837,766
Posts: 34 |
If you should follow a blog this summer, this might be the one http://peking2paris2016.no
Ragnar 2000 mod +4
Posts: 27,822 Likes: 750
Posts: 27,822 Likes: 750 |
Looks like a brilliant time will be had reading that.
Posts: 1,415 |
You wont believe the amount of trick engineering I put into that chassis.
Most of it is built from aerospace grade steels
There is even advanced low friction polymer interleaving of the rear springs to stop them digging into each other and breaking....
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 343 |
2004 GTN #5 sold 1989 Plus 4
Posts: 1,224 Likes: 7
Posts: 1,224 Likes: 7 |
Definitely a must read. Good luck!
1968 4/4 1600 1950 Auster J5B Kitfox S5 Outback Jodel D9 1988 Peugeot 205 GTI 1.9
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
It will be very interesting to follow this blog. I have a similar dual damper air suspension on my +4 four-seater. This will be the ultimate test of the suspension. Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 1,943 |
When I asked about the feasibility of a Morgan for the "Peking To Paris" I was advised to forget it. A Morgan Friend from Victoria, BC did the PTP last time with a Rolls Royce Phantom III. He and Wife finished but tire and generator problems made this a challenge. This time He and the Mrs. will use a 1928 Nash Roadster. They were in Alaska last Summer at the same time I was, testing the Nash. You can bet I will follow the PTP Blog.
Button Seattle
Button
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Definitely a must read. Good luck! Yes thanks for posting and indeed good luck
Posts: 4,896 |
Thanks for posting will definitely follow this, and good luck to all entrants.
Adrian
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Thanks for posting will definitely follow this, and good luck to all entrants. +1
Richard 1976 4/4 4 Seater
