8 members (planenut, Image, Montegue, RichardV6, JohnHarris, Morganmike, tommog, Zach), 294 guests, and 35 robots.
+8Rich 94
John V6 52
Posts838,001
rockabilly john
You may find this useful reading
http://www.gomog.com/allmorgan/wheelsindex.htm
The splines on the hub can be razor sharp. Don't touch them.
I would always apply a little copperslip when refitting the wheel.
On my car the front discs can seize slightly if I put it in the garage wet
If the front brakes have seized, freeing them will be easier by just driving the car back and forwards.....they will release with a bang! It sounds like harsh treatment but won't cause any damage.
Condor Offline OP
Originally Posted By IcePack
Not being silly, but are you sure it is the hand brake/rear brakes?
A couple of months ago I had a devil of a job to get my front brakes to release especially near side.
Thank you - and how did you solve that problem please?
I haven't been able to look at my car today - it will keep for the weekend.
Oct 13 build 4/4
As Jays said forward & back. But the near side ended up being dragged about 5 meters (locked solid) then a very determined drive forward. Big Bang then free but took some miles & heavy braking to stop the brake judder, due to the marking on the disc. Taking advice from this forum I now let the car stop on its own when pulling into the garage. I.e no application of the brakes. So far no re-occurrence.
I had had them stick a bit before but nothing like the last time. The car had been left a little longer than usual so maybe that compounded the issue.
Good luck & be carefull when " clouting" the wheel nut tool as it is easy to hit the wheel arch.
Condor Offline OP
Again thanks everyone.
I love the generosity of people with their advice and time on this site.
Oct 13 build 4/4
I have always been able to release a locked brake by just grasping the top of a wheel and rocking the car back and forth. However, I am sure that I am not alone in having to have the rear brake cylinders replaced. They have a habit of both leaking and sticking. Worth checking.
Bud
4/4 "Stanley"
SBM Offline
One of the by-products of not changing the brake fluid every two years, is that the hygroscopic nature of the stuff means water gets in the system and corrodes the actuation cylinder barrel. This can bring about sticking if left, too.
Condor, I trust this issue is soon resolved. Pulling the brakes off (if need be) is no big job but be sure the car is well supported on stands, chock he wheels and leave the jack well positioned for good order.
