1 members (RedThree),
194
37
Topics49,911
Posts838,152
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I had lunch in an Italian restaurant today. The grilled fish was excellent!
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
I'll share the definition of a "Hewitt" with you if you promise not to tell ah sole...
hewitt
the act of scaling a flight of stairs by running full speed. Hewitt syndrome causes the inability to walk up or down flights of stairs. One who hewitts must run down/up them without exception. We also have identified that hewitting stairs is hereditary and will inflict entire families. Expert Hewitts can climb a 12-step flight of stairs in approximately 3.2 seconds. The title "Master Hewitt" is obtained when one can skip every other stair and scale a standard 12-stair array in less than 3 seconds. If someone develops the Hewitt syndromm, there is no cure and it becomes completely involuntary and uncontrolable. Hewitt syndrome becomes worse over the years and hase not yet been found curable. Evidence supports the only way to deal with the Hewitt epidemic is prevention. Removal of all stair cases and replacements with elevators, rope ladders, and firemans poles. NEVER LET A HEWITT AROUND AN ESCALATOR, Results could be deadly, some say hewitts can travel up a moving escalator at nearly 25 mph or 6 stp(stairs per second). This can be dangerous to anyone in the vicinity.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Up until my cartilage operation I was ...but I only found out tonight on the "urban" dictionary.
Posts: 14,009 |
Well I know one thing with absolute certainty......I'm not the father. Never fancied his mother one little bit.
Posts: 1,642 |
... Never fancied his mother one little bit. Not sure if you British are familiar with La Fontaine (being a frog, not called Shakespeare, all that ...), but
Posts: 4,896 |
Jays just noticed your revised signature with "Carry on to Caramulo... ", I hope this is not a rerun of Carry on up the Khyber  by the way which character are you in the cast?
Adrian
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
by the way which character are you in the cast? Bungdit In?
