1 members (Daniel Craig), 290 guests, and 43 robots.
+8Rich 94
John V6 49
Posts837,991
rockabilly john
#361891 05/05/16 07:19 PM
It's on the top crossmember behind the spare wheel, is this a DIY job to replace?
1983 Plus 8 (on carbs)
1975 Land Rover 109" full tilt
1989 Caterham
1999 Honda Fireblade
There is no reason it shouldn't be provided you are happy with removing the panels and replacing them to gain access, all the parts are available if you don't fancy the ash work yourself.
http://www.harpersmorgan.co.uk/Other/woodframes.htm
Bob has passed on now but Roger is most helpful and knowledgable and will give you good advise.
I bought my car from them a couple of years ago they are one of the older established companies.
GaB
Unregistered
GaB
Unregistered
Ye gods.
I have never seen rot like that before.
Looks like some voracious animal took a bite out of it...
To do the job properly, I would think you'd need a specialist, and I suspect the resultant bill would not be small - a lot of the tub would have to come apart to get to it.
If it were me and I found myself at a pecuniary disadvantage, I'd probably use liquid epoxy wood repair to stabilise and harden the existing wood, drill and inject a few boron rods to kill off any rot and prevent any new occurrence, screw a strengthening piece below or behind it to restore the strength, and re-form the profile with epoxy to make it look neat again.
If they can use epoxy injection and boron rods to fix roof timbers in houses, it should be ok for a non-critical body frame component, I would have thought.
Looks a bit like dry rot to me. If you have the hand skills plus tools, it's a straight forward job. The issue will be whether the rot has affected other areas making it a much bigger job.
Martin (Deano)
Black Rat
Black Rat
Dry rot in a Morgan ooo I would expect wet rot not dry notworthy cut it out immediately before it spreads nono
Keith
2013 narrow bodied + 4 Ruby.
If its spongey and damp them it's wet rot and just needs the soft areas replacing and surrounding areas hardened with wood hardener
If it's dry rot it goes powdery and will be dryer to the touch - this is caused by a fungal infection eating away and is a bit more serious as the fungus spreads
Richard,
Here is a scan of an old Harpers catalogue and might be of help to you, it's about 11 years old so the prices will be irrelevant but the part numbers should be consistent.
No fancy showroom or salesman here but their wealth of knowledge, enthusiasm and love of the brand is infectious.
I have used Tim Harris's approach for years. It is called "CPES" Clear Penetrating Epoxy Sealer". Not sure what they call it in the UK. But a Marine Chandler will know about this stuff. But as somebody on TalkMorgan pointed out this looks like the "Tip Of The Iceberg". I have repaired structural damage that was worse than the picture. But I am thrifty (cheap) and I try to catch this stuff before it gets to be major. I have used Epoxy Putty to rebuild pieces of wood and painted them so one really would not know I had used this approach. You will hear over and over, "If You Are Going To Do It Do It Right". Yea and have money to burn also.
Button
Seattle
Button
If this piece is just screwed in and accessible than it would be crazy to not put a new timber in. In any event You would have to remove the back deck. On My +8 Bitsa it is easy. But not sure about a later model.
Button
Seattle
Button
