7 members (Image, andymog1, DJC, John V6, Simon, TalkMorgan, IcePack), 252 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,119
#363307 11/05/16 05:51 PM
Hi chaps what dot is it ,must try fix the break ,all the fluid leak out in france
Thanks scott
Q
Q
The brake fluid dot is on the cap..remove the bonnet
Dot 4.
In an emergency like this just use any "fresh" glycol based brake fluid you can source locally, DoT 3 or DoT4 will be fine. DO NOT USE SILICONE based fluid
Please change it once you get back to UK with a recognised branded DoT 4.
Andy G
1999 +8 , Indigo Blue.
I'm home ,was at the Albert ball run in France ,took it slow coming home
Thanks scott
Best investigate the leak first!
All the fluid leak out in France ..
What do you mean?
When I pull up in France with all the others some one notice the rubber on the nipple was missing ,pushed break pedal nothing ,tried to tighten up ,the next morning bubbles was coming up the thread on the nipple ,break's was very hot ,did the metal expend because of the heat ,because it stopped leaking when I got home ,will bleed tonight and keep a eye on it
Q
Q
Even without the rubber it should not leak!! maybe the nipple is faulty or SOMEONE LOOSENED IT!!
