Topics49,909
Posts838,126
Posts: 303 |
Hi chaps what dot is it ,must try fix the break ,all the fluid leak out in france Thanks scott
Posts: 1,338 |
The brake fluid dot is on the cap..remove the bonnet
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
In an emergency like this just use any "fresh" glycol based brake fluid you can source locally, DoT 3 or DoT4 will be fine. DO NOT USE SILICONE based fluid
Please change it once you get back to UK with a recognised branded DoT 4.
Posts: 303 |
I'm home ,was at the Albert ball run in France ,took it slow coming home Thanks scott
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Best investigate the leak first!
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
All the fluid leak out in France .. What do you mean?
Posts: 303 |
When I pull up in France with all the others some one notice the rubber on the nipple was missing ,pushed break pedal nothing ,tried to tighten up ,the next morning bubbles was coming up the thread on the nipple ,break's was very hot ,did the metal expend because of the heat ,because it stopped leaking when I got home ,will bleed tonight and keep a eye on it
Posts: 1,338 |
Even without the rubber it should not leak!! maybe the nipple is faulty or SOMEONE LOOSENED IT!!
