11 members (High Hamster, Ruut Bianchi, Luddite, mph, Alan Patterson, TalkMorgan, TBM, linklaw, Sir Percival, John Winn, JohnHarris),
252
35
Topics49,912
Posts838,165
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
Harald, How does the air suspension setup work, it sounds ideal.. Would it be expensive to fit? The air suspension retains the original leaf springs and the original Bilstein dampers. Two additional air suspension dampers are fitted along with a compressor. A switch under the dashboard allows the driver to release the air pressure to lower the car or increase it to gain ground clearance. Air suspension is progressive so it acts as a soft bump stop in addition to controlling ground clearance. It would be possible to add a pressure gauge, but so far I adjust the pressure depending on the number of passengers and the road conditions. The cost in 2014 was £2800 of which £1100 was for the parts. This is not cheap, but I am very happy with the result. Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Roger, I would be interested in a 2 seater set if the price is right John No problem John. If they do come to fruition I don’t think they will amount to very much.
Roger 2011 Plus 4
Posts: 27,848 Likes: 766
Posts: 27,848 Likes: 766 |
Roger thanks I will try filling the piggy bank then!!
