Topics48,341
Posts813,001
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Wonderful stufff.
I still have a box of "long" socket/light switch screws so may do the same.
The difference may also explain why I can never get my brake/tail lights quite tight in the holder as per the different length issue above.
Richard 1976 4/4 4 Seater
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
Don't forget the O-ring for the screw head! Stops water ingress. A common-ish issue. My n/s indicator bulb was rusted in solidly due to the lens filling with water hence no chance or replacing a failed bulb. Bought a replacement bulb holder unit.. Temp solution was drill drain holes 1mm tried first but ended up with 2mm.
A good point
