8 members (Farmershands, KLASG, DickJ, Vansrv6, Robbie, James B W, John V6, esse16),
202
52
Posts837,945
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
Great forum folks! Have been self-educating as I consider (plan) a M3W. I have seen plenty of posts regarding taller drivers, but I'm concerned about the opposite. I'm 5'8" but my inseam is only 30, with 32 inch sleeves. I realize the pedals are adjustable and the wheel and seats are not. I saw a YouTube video where someone appears to be driving with a matching seatback bolster. Is there enough forward adjustment to the pedals for someone my size to have no problem reaching them? Anyone use a seatback extender/bolster to be closer to the wheel? Thanks in advance and for all the helpful info on these boards.
Aka Joejoe
Posts: 1,490 |
You're at the acceptable lower end. You'll be find with the pedals at the rearmost setting. Might need a steering wheel spacer.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Yes ask Brands Hatch Morgans . For padded seat cushions made to fit.
Posts: 242 |
You will be fine. I'm shorter than you and have the pedals on the 3rd rearmost setting (out of 4). The factory also made the base cushion thicker so that I can see the top of the nearside wheel.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I'm 5'9" with a 31" inseam, my pedals are set at the furthest location and I have a 1" spacer on the steering wheel.
With this set up it is the most comfortable I have ever been in any car ever.
5 hours without a break is no problem and no numb bum either.
I doubt very much weather you will need any form of booster cushion on the backrest.
Posts: 462 |
Perfect size for all Italian beauties ! And of coarse M3W 😊 The petals can be moved (bolted) to anyone's legs length the only issue are how wide you are!
I'm 5'6 with 29" inseams 34" waist and I never moved the pedals from the factory setup
As long as you can see over the hood, not over 250lbs wide along with having a smaller riding partner, you should be good 👍
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 1,490 |
I doubt very much weather you will need any form of booster cushion on the backrest. All depends on the whether (damn I'm funny)!
Posts: 257 Likes: 3
I doubt very much weather you will need any form of booster cushion on the backrest. Do you mean furthest forward or furthest toward you? Thanks for all replies!
Aka Joejoe
Posts: 257 Likes: 3
You will be fine. I'm shorter than you and have the pedals on the 3rd rearmost setting (out of 4). The factory also made the base cushion thicker so that I can see the top of the nearside wheel. Was that a special order?
Aka Joejoe
Posts: 1,490 |
Your last two questions were questionable.
