Posts837,951
Posts: 1,213 |
I'm a similar size to you Joejoe , as everyone else has said you'll be fine . The car is certainly not designed for large people . I did put a piece of firm foam behind the lower part of the seat back to give me a bit more lower back support .
Hugh
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
The designer of the current iteration of the car is just about your size. Gets in and out quite easily and has a comfortable drive. All of us larger, taller people hate him... He obviously designed the car for himself. Cheeky
Posts: 400 |
I'm 5'8", with a 30" inseem, and it is very comfortable to drive. Surprisingly so. I used to be 300 pounds (now twosixty-ish) and even then it was a good ride. I moved the pedals one step towards me from the factory position. A fifteen minute job, no problem.
Go for it! *s*
M3W, now!!!
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
My pedals are as far forward as possible.
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
I am the same size within an inch but with only 29" inseam. I have no problems at all in the standard car. As others have said, you can adjust the pedal box.
Posts: 242 |
You will be fine. I'm shorter than you and have the pedals on the 3rd rearmost setting (out of 4). The factory also made the base cushion thicker so that I can see the top of the nearside wheel. Was that a special order? Yes. They have to make the back rest shorter to compensate for the deeper base cushion.
Posts: 541 |
I am the same size within an inch but with only 29" inseam. I have no problems at all in the standard car. As others have said, you can adjust the pedal box. +one, I have a 2013 model year.
1998 +8 SS Sport tuned exhaust
2013 M3W Stage ll motor kit Cats removed
Posts: 6,538 |
Should be no problem.
But have the pedals moved back to the fullest extent/ pre drilled holes.
Neil
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
Aka Joejoe
Posts: 42 |
I'm 5'6" with a 29" inseam. I thought I would need the pedals moved to a short rider position but the dealer talked me out of it. I find that if I drive for any distance at all I want space to stretch out my left leg without resting it on the clutch. If you move the pedals closer to you then you have less space for that. I am glad I left the pedals in the center position.
