3 members (bmgermany, RichardV6, Mick Annick), 196 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
#37659 20/11/09 08:21 PM
Ivo Offline OP
TM Photographer of 2011
As promised.... smile
1. Move the fog- and back-up-lights.
2. remove screws "1" (there are four) Don't touch "2"
3. remove the number-plate lights and ...gotta be brave for doing this... cut away the upper part scared
4. Install a standard number-plate holder with two stainless steel angles
5. Install one of the number-plate lights. I did it with a piece of aluminum sheet metal.
et voilą roses
sunny
1998 +8 (permanently out of service frown )
Nicely done Ivo. thumbs
Cutting that plastic panel takes serious effort....... laugh2
Ivo Offline OP
Thank you, Dave smile
Oh, absolutely... but seeing the result... love
sunny
Dave eat your heart out!! You have competition!!
Very helpful. It appears that you were able to take the panel right off the car to cut it (Otherwise it would have been even harder to cut it I guess). I am therefore assuming that you were able to get it over the over-rider brackets without removing them then?
Exactly! thumbs
Before and after photos here, for those who missed them! (like me doh )
Ivo, it looks really good and I like how it tidies up the rear of your car.
Ivo Offline OP
Originally Posted By Simon
(...) Ivo, it looks really good and I like how it tidies up the rear of your car.
Thank you, Simon smile
I never liked the original holder, and I wanted to change it from the beginning. But it took me more than two years before I decided to cut it away. You see... I'm not THAT brave innocent
Sunny Greetings,
Ivo
sunny
Ivo Offline OP
Thank you smile
I left the panel on the car. Just removed the upper screws (1) pulled it, and cut carefully along it. It worked very fine with the metal saw holder, as seen on the picture.
sunny
Green & Grown Up
Green & Grown Up
NIce Post - A Very Neat finish, Ivo thumbs
Originally Posted By Ivo
et voilą roses
The Reverse and Fog lights on the Roadster 100 are closer together so a bit more head scratching first. idea
Ivo Offline OP
Thank you, Frank smile
So were mine:
I had to move them first
Sunny Greetings,
Ivo
sunny
Frank regarding your comment - "The Reverse and Fog lights on the Roadster 100 are closer together so a bit more head scratching first."
(Moderator - How do you include the bits from other post in your replies?)
I did read somewhere that we only need 11mm border from the extremeties of the font so it is possible to make your plate narrower if needs be. wink
Keith
