11 members (How, Chris Cosher, +8Rich, John V6, RichardV6, Montegue, John Winn, Fuel.inj, bmgermany, DCH, Rog), 167 guests, and 38 robots.
+8Rich 79
Luddite 50
Posts837,932
HJP Offline
I'm a similar size to you Joejoe , as everyone else has said you'll be fine . The car is certainly not designed for large people . I did put a piece of firm foam behind the lower part of the seat back to give me a bit more lower back support .
Hugh
The designer of the current iteration of the car is just about your size. Gets in and out quite easily and has a comfortable drive. All of us larger, taller people hate him... He obviously designed the car for himself. Cheeky
I'm 5'8", with a 30" inseem, and it is very comfortable to drive. Surprisingly so.
I used to be 300 pounds (now twosixty-ish) and even then it was a good ride.
I moved the pedals one step towards me from the factory position. A fifteen minute job, no problem.
Go for it! *s*
M3W, now!!!
My pedals are as far forward as possible.
I am the same size within an inch but with only 29" inseam. I have no problems at all in the standard car. As others have said, you can adjust the pedal box.
Originally Posted By Joejoe
Originally Posted By MO63WLR
You will be fine. I'm shorter than you and have the pedals on the 3rd rearmost setting (out of 4). The factory also made the base cushion thicker so that I can see the top of the nearside wheel.
Was that a special order?
Yes. They have to make the back rest shorter to compensate for the deeper base cushion.
+one, I have a 2013 model year.
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
Should be no problem.
But have the pedals moved back to the fullest extent/ pre drilled holes.
Neil
Thank you to all!
Aka Joejoe
I'm 5'6" with a 29" inseam. I thought I would need the pedals moved to a short rider position but the dealer talked me out of it. I find that if I drive for any distance at all I want space to stretch out my left leg without resting it on the clutch. If you move the pedals closer to you then you have less space for that. I am glad I left the pedals in the center position.
