1 members (JMcL),
235
41
Topics49,904
Posts838,083
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
As promised.... 1. Move the fog- and back-up-lights.  2. remove screws "1" (there are four) Don't touch "2"  3. remove the number-plate lights and ...gotta be brave for doing this... cut away the upper part  4. Install a standard number-plate holder with two stainless steel angles  5. Install one of the number-plate lights. I did it with a piece of aluminum sheet metal. et voilą
 1998 +8 (permanently out of service  )
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Nicely done Ivo.  Cutting that plastic panel takes serious effort.......
Posts: 963 |
Nicely done Ivo.  Thank you, Dave  Cutting that plastic panel takes serious effort....... Oh, absolutely... but seeing the result...
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Dave eat your heart out!! You have competition!!
Very helpful. It appears that you were able to take the panel right off the car to cut it (Otherwise it would have been even harder to cut it I guess). I am therefore assuming that you were able to get it over the over-rider brackets without removing them then?
Posts: 7,934 Likes: 133
Posts: 7,934 Likes: 133 |
Nicely done Ivo.  Cutting that plastic panel takes serious effort....... Exactly! Before and after photos here, for those who missed them! (like me  ) Ivo, it looks really good and I like how it tidies up the rear of your car.
Posts: 963 |
(...) Ivo, it looks really good and I like how it tidies up the rear of your car. Thank you, Simon I never liked the original holder, and I wanted to change it from the beginning. But it took me more than two years before I decided to cut it away. You see... I'm not THAT brave Sunny Greetings, Ivo
Posts: 963 |
Very helpful. It appears that you were able to take the panel right off the car to cut it (Otherwise it would have been even harder to cut it I guess). I am therefore assuming that you were able to get it over the over-rider brackets without removing them then? Thank you  I left the panel on the car. Just removed the upper screws (1) pulled it, and cut carefully along it. It worked very fine with the metal saw holder, as seen on the picture.
Posts: 3,727 |
Posts: 963 |
NIce Post - A Very Neat finish, Ivo Thank you, Frank The Reverse and Fog lights on the Roadster 100 are closer together so a bit more head scratching first. So were mine:  I had to move them first Sunny Greetings, Ivo
Frank regarding your comment - "The Reverse and Fog lights on the Roadster 100 are closer together so a bit more head scratching first." (Moderator - How do you include the bits from other post in your replies?) I did read somewhere that we only need 11mm border from the extremeties of the font so it is possible to make your plate narrower if needs be.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
