4 members (DJC, MATTMOG, Sir Percival, BLUE+4), 214 guests, and 50 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Page 3 of 3 1 2 3
ok.
I dont have any leaks and am just being belt and braces so will just replace the 4 on top for the moment and see how it goes.
Thanks
In aircraft maintenance circles this would be known as a trend. As Nippy suggests it is probably wise to replace them. You don't want fuel spraying onto a hot engine. Later cars only have these compressed clips on the inter-connecting pipe. Someone said they had problems removing them. A thin screwdriver and a gentle tap in direction of the arrow will unlatch them. (if it is this type)
Robert
Just changed mine at the weekend , the top 4 on the engine at any rate.
They prise open exactly as Grockle describes , but I would like to add : as fitted the main loop has very small tabs to hold the loop closed.
On three of them I could simply prise open the main loop , but on one I had to open the small holding down tab before I could get the main loop open. Maybe doesnt apply to other , but until I noticed it I couldnt get the clip to open.
If you believe the universe is only 6,000 years old, you're not allowed to use fossil fuel. Then you won't have to worry about leaks.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Austrian,
I had the same problem months ago, with petrol spraying on the windscreen and it was the clamps. I have fitted additional clamps next to the original and the problem disappeared.
If you believe that the earth is only 6000 years old and that dinosaurs froliced with humans, the petrol is..... People!
kirkusblog.com
1952 Ford 8N
Draggin, that is only a problem in god's own country and some taliban areas.
Most other people provide proper education to their children.
evil wink
BTW: The smell disappeared from my M3W after I replaced a broken cylinder header cover gasket. It was oil, slowly leaking out of the cover, dropping onto the exhaust area that produced fumes.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Check your tanks and tank mounting points and bolts - lift the car and check from underneath.
Also take a look at the tank transfer pipe couplings for perishing.
Rgds M
Page 3 of 3 1 2 3
