Posts838,003
Posts: 1,597 |
Mark Do you know what the origin of the high pressure hoses were
Posts: 336 |
I'll ask Phil at ledger wood when I collect the car in a few weeks time. I suspect it would be cheaper to have them made up as the fittings will be fairly universal, just the length and internal bore spec needed.
Posts: 536 |
Mark, I 'm glad that Graham's diagnosis of a PAS hose was correct and it's not the more serious mechanical failure.
If you are able to find out what caused the hose to fail (age, rubbing or defect) and could advise I'd be most grateful. I'm taking the front end is coming off mine after the summer and I'll check all the hoses then.
Cheers
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 336 |
Oh and I found out today that we raised £55k for children in need from the sporting bears at car fest north.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
£55K is an amazing sum to have raised.Well done to all concerned  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 108 Likes: 1
Posts: 108 Likes: 1 |
Hi Sorry for late answer, back in Spain and only just picked up your email.I have a full set of pictures and installation instructions back at home that I can forward on, but not back until middle of September. Bill
Posts: 1,597 |
Mark, Well done for your part in the incredible fund raising total, hopefully your repair bill will be a lot less. Grateful for any details on your job when you speak to the dealer.
Bill, gratefull in the autumn for your notes and images when you return
Dave
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Cheers Might just be best to go to someone like Pirtek and get new replace hoses anyway. Everything ages and eventually fails, and decent hydraulic hoses arent expensive from a specialist as opposed to MMC.
