6 members (TalkMorgan, riri, Dougie, Tresco, DCH, Montegue), 292 guests, and 30 robots.
+8Rich 93
John V6 49
Posts837,988
#384456 12/08/16 08:52 AM
Sukram Offline OP
I have a brake pulling to the left side,
Check and purge for air bubble. Clean brake disk, green pads ok, fix all screw, wheel turn well without brake.
You fell it really only if you brake hard by higher speed.
Any idea, thanks for help
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
E
E
Check the operation of the back brakes are they both similar.
Go out for a run of say 2 or 3 miles without using the brakes.
Be very careful here, are both brake discs the same temperature do not burn your self!!!!!!!!!!!!
I'm wondering about a brake caliper starting to sieze on which will be intermittent when it starts.
Also from speed if you just put the brakes on gently are you getting any judder through the pedal. In that case renew both front discs.
It's one of your brake caliper pistons seizing
you should be able to work it free
if not its a £20 note to uncle melvin and a seal kit to fit
how do I know......
guess what I'm doing to my car tomorrow morning
I fitted new pads and when I backed the pistons back into the caliper the Fos inner was stiff.
car now pulling to left under braking
Time to strip / clean pistons and rebuild
Messy job
doh
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
Rear brake cylinder is my guess....
Black Rat
Black Rat
+ 1 common fault
Keith
2013 narrow bodied + 4 Ruby.
+1 it was with my 4/4.
Check the flexible brake hoses as well if they have not been replaced since 1985. Sometimes they break up internally which causes them to act as a one way valve giving rise to a seized caliper/wheel cylinder type symptoms when there is nothing wrong with the caliper or cylinder
Arwyn
+1 , and change pipes to Aeroquip type, cheap enough these days...
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Sukram Offline OP
Thanks for answer, i found it, and test it the last weekend =700km.
Stupid, i had control all, but not the Brake Reaction Stays (Crosshead brace), on the left side, the screw what bad quality from the past owner and overturned, i replace it and it works
Unbelief that the front move so match without this simple steel parts
BMW R1200 GS
Triumph TR140
Sukram be careful the bolts on the brake reaction bars are designed to fail in a crash.
