3 members (John Winn, JohnHarris, RedThree), 194 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
My 1989 +4 head gasket is leaking oil at the rear; had head off, head OK, new gasket with recommended sealant fitted; still leaking. Any suggestions please
Previous engines did not have the MLS gasket and did the usual T series and M series and O series, weep from the cylinder head/block join around the cylinder number 4 corner, at the front. You will see it immediately, sometimes it is just a little damp corner with some dried oil indicating hardly anything, other times it is gushing out. Is that so in your case? Mine weeped a bit at 30000 miles and the head was skimmed before it was replaced.
Engines can be retro fitted with the newer head gasket but the oil restrictor in the block needs to be removed, which can usually be done with a screw and a pair of mole grips. Cleanliness is paramount and every minute spent in preparation of the head and block surface is vital and they should be perfect for the best end result and no more oil leak.
Cam covers always leak oil, and need cleaning up and new seals. It's easy to strip cam carrier bolts when putting cam carrier back because the T series uses 8 or so large bolts, which when you are doing the carrier up have to depress the cam, so these bolts need doing up in sequence, very progressively.
p.s I sourced my head gasket from Phil Wareham at Brands Hatch Morgans.
Thanks for response
Mine is leaking and rear of head; its quite a 'flow' down the block and bellhousing; you can wipe away across the 'flow' and watch it 'running'
