7 members (JMcL, cerealsurfer, RichardV6, RedThree, simon8201, Dek, AlyMatt), 307 guests, and 31 robots.
+8Rich 91
John V6 49
Posts837,985
Page 3 of 3 1 2 3
flyingpig
The washers/spacers helped a little in the 2-5 range 1st is still a bit of a pig - I wonder if the passivated housed bush to the rear needs spacing a little, the assembly rotates okay but it moves back and for by about 1/2" that may be a requirement but I may have another fiddle later in the week.
Mark - No Longer driving
Formerly known as Aldermog
Originally Posted By Jays
It would be interesting to see what alternative gearbox options there are and how easy it would be to change.
Before I swapped Aldermog for Tarka I had a long discussion with Tim Ayres at New Elms about taking out the Ford V6 engine and gearbox and fitting the Ford based V6 from an S Type jag, complete with /auto box. As the S types rust there are plenty of MOT failures.
The result would be in effect an S1 Roadster Auto....but we got to about £10K as an estimate and about 4 months. Then Tarka appeared and the rest is history.
I am going for a T5 as previously mentioned eventually a nice box that can more than handle the V6 3.0 I have.
No interest in yet another Auto - the Mog is Raw and compromised and that is the way I like it!
Had a really nice run along some of my alternate routes from my old Wallop commute today, I did get a little wet, and the A303 is still a nightmare even on a Sunday.
Today's run back and forth to work, I think the plastic spacers actually have helped a bit, I'd have to remove the tunnel to see if there is any slop in the front of the extender.
Page 3 of 3 1 2 3
