8 members (thelastgizmo, Luddite, JohnHarris, Mike D, Craig Jezz, DJC, +8Rich, Montegue),
275
42
Posts837,993
Posts: 128 |
BTW, I think with the strap tight now, there's little chance of significant damage.
Had the scratches been lighter (smaller), I think I might have removed the strap and put it in storage for a future owner or change of mind.
I understand the attraction of the strap, but would not have chosen one for a car I ordered.
Posts: 1,490 |
But is the paint a color base with a clear top coat? A single stage, water-based paint? Anyone have a clear idea of what the paint is so something compatible can be chosen? He said it isn't paint.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 128 |
Sorry to be confusing. Yes, the radiator cowl is stainless, but I'm referring to the body color -- which, last I checked, is paint.
Posts: 133 |
Hi James. Last year i bought a kit for my 3W on Chipex on line site. Chipex is the official paint used by Morgan motor company. You can choose your color and the dimension of the kit and then pay for it using your credit card. I had a pair of stone chips and my paint is ok after i used the kit. I hope this could help you www.chipex.co.uk
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
James,
I can thoroughly recommend Chipex having used them recently. Provided you give them the correct paint code, your paint will be an exact match.
Posts: 469 |
I also recommend chipex, used it on all my cars, brilliant results!! Ian
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
+1 on Autosol, wonderful stuff and it's cutting power is deceptive considering its creamy consistency. Work wonders on Moto Litas and alloy fuel caps too.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I used Chipex a while ago, gave them the paint code that MMC advised was the correct one for my car but it turned out to be miles off.
Rang Chipex who were wonderful, said they couldn't help but gave me a full refund no quibble.
Still I would have preferred the right shade of blue rather than the refund.
Posts: 1,947 |
My dealer scrounged some paint for me when at factory. Its a 2 pack, mix 2 parts paint 1 part hardener. I've not used it yet. I have some bubbling/corrosion under the paint where the rear indicator pod mount passes through the panel. How best to tackle this?
Tim
Posts: 4,896 |
With caution, I believe 2 pack paint gives off a poisonous gas when mixed and breathing apparatus is required. Obviously the rest can be accomplished by stripping down, rubbing back to metal, anti corrosion treatment, careful prep with undercoat and several rub downs with lessening grade wet and dry till a perfect finish ready for the top coat.
Adrian
