10 members (Mogdavid, JoeSpeetjens, jbk, Plus Four Guy, Jock, RobS, simon8201, IcePack, MartinB60, PaulJ),
299
Posts837,973
Posts: 3,701 Likes: 133
Posts: 3,701 Likes: 133 |
On my "classic" the back of the handbrake switch was been packed with a thick washer to adjust the height of the switch protruding. I guess mine must be the same, I will take a look. In 9 years of ownership my handbrake light has worked just once! It came on one evening when I parked up, much to my surprise as I didn't know there was one! The next time I released the handbrake it went off again and I've never seen it since. I'd forgotten all about it until I read this thread. ~iw
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
On my "classic" the back of the handbrake switch was been packed with a thick washer to adjust the height of the switch protruding. I guess mine must be the same, I will take a look. In 9 years of ownership my handbrake light has worked just once! It came on one evening when I parked up, much to my surprise as I didn't know there was one! The next time I released the handbrake it went off again and I've never seen it since. I'd forgotten all about it until I read this thread. ~iw On "classics" they are also earthed at the switch but as the switch is plastic there is a fly earth lead. Could be this. You'll find (if like mine) the washer is "trimmed" so that it fits against the side of the handbrake housing. They are held in place by a nut so this may have also come loose. The nut does not come with a replacement switch so keep this safe. The part you need is Lucas SMB421 and is easily available on eBay for much less than the dealers. With postage about GBP7. It's fiddly to do from underneath without removing anything but quite doable. If testing with a multi-metre remember it is normally closed and push to open.
Richard 1976 4/4 4 Seater
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
The phrase "value engineering" springs to mind... On a Dacia maybe...
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Why didn't they use a hall effect proximity switch? adjustable to the height it needs to detect the metal at!
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Why didn't they use a hall effect proximity switch? adjustable to the height it needs to detect the metal at! This is a Morgan we are talking about!! I suspect that the hand brake warning switch isn't part of the legacy BMW can-bus system!
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
This was the 2005 trad set up. And quite easy to get at from underneath..........
Posts: 272 |
Interesting my parking brake is on permanently. I may take a look.
Morgan +8 Morgan Club Sport
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Uff... Next WE I think I'll have to do the same job.
In 9 years of ownership my handbrake light has worked just once! It came on one evening when I parked up, much to my surprise as I didn't know there was one! The next time I released the handbrake it went off again and I've never seen it since. I'd forgotten all about it until I read this thread. Update: It's twice in 14 years now ... it came on again this morning. ![[Linked Image]](https://www.tm-img.com/images/2022/01/02/2022-01-02-handbrake.md.jpg) One of the things I love about Morgans, the idiosyncracies!
