2 members (jim109b, linklaw),
303
Posts837,990
Posts: 2,190 |
Dave, agree with the carbs comment- six Webers on a V-12- now that I would like. On the other hand, I wouldn't say no to a Holley or a Rochester on a Cobra- and I know I can get into one of those! Time to mug my bank manager perhaps
Final question: who buys yellow Ferraris?
Regards
GLLHG
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
If I had the money... Dinos look fantastic in yellow
GaB
Unregistered
GaB
Unregistered
An update on this rather historic post as I also need to repair the inevitable chips of life on the road (and in the garage). Archie is Corsa Red, which as DaveW rightly points out is also Ferrari Rosso Corsa. I have just ordered a Chipex set, which for Corsa Red is paint code 322. If anyone else is thinking of buying one of their chip repair products, the top of the range set is £37.95 + £2.99 postage (£40.94 total). However, using voucher code 'TryChipexzc1812' brings the price down to £34.15, which sounds much better.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
An update on this rather historic post as I also need to repair the inevitable chips of life on the road (and in the garage). Archie is Corsa Red, which as DaveW rightly points out is also Ferrari Rosso Corsa. I have just ordered a Chipex set, which for Corsa Red is paint code 322. If anyone else is thinking of buying one of their chip repair products, the top of the range set is £37.95 + £2.99 postage (£40.94 total). However, using voucher code 'TryChipexzc1812' brings the price down to £34.15, which sounds much better. That's very helpful - thanks My car is a year 2000 Rosso Corsa red which should be exactly the same let me know if it's a good match when it arrives and I'll order a set
GaB
Unregistered
GaB
Unregistered
A wise move Stewart. There are so many reds, and not all of them are the red you need, even if it says so on the tin. Anything would be better for me than the previous chip repiars and most unsightly white undercoat. However, after 15 years of life Corsa Red might be a near miss rather than spot on. Morgan life.
A wise move Stewart. There are so many reds, and not all of them are the red you need, even if it says so on the tin. Anything would be better for me than the previous chip repiars and most unsightly white undercoat. However, after 15 years of life Corsa Red might be a near miss rather than spot on. Morgan life. I wouldn't be too pessimistic - I got Rosso Corsa red spray paint mixed at Halfords - they didn't have the Morgan related information so I asked for Farrari Rosso Corsa of around the year 2000 (i think in the end it was from the mid to late 90's) I used it to spray the back of the my Cibie (copy) spots and it looks spot on (no pun intended) The chap who I bought the morgan from said that Morgan used Ferrari's paint for the Corsa red don't know whether that's true but it certainly looks the same
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
It's Ferrari Corsa Rosso. I got mine from Halfords as a mixed aerosol and a touch up with a brush. There are three specs, and from memory I think that mine was listed as 300/12. If I may quote myself.......... Just be aware that there are three mixes.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
When I bought my 1993 Corsa Red 4/4 it came with a small tin of touch up paint . I kept it when trading up to a 2002 Plus 8 in Corsa Red and the match is good. Unfortunately there is no paint code on the tin. Thanks for the update re it being Ferrari and the 3 versions from Halfords. Handy if more needed.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
If I had the money... Dinos look fantastic in yellow Im with you there .
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The nice guys at Chipex identified the Rolls Royce OEM code for the paint on Tarka, so I'm set up with an easy solution!
