0 members (), 230 guests, and 23 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
#392333 13/09/16 02:28 AM
JamesB Offline OP
I've seen references to changing the fluid in the M3W manual transmission.
A YouTube video about servicing a Mazda Miata 5-speed showed also replacing 90cc's of transmission fluid at the base of the shifter. That has to be done separately from the main reservoir.
Does that apply to our transmission? (Seems like it would.)
Thanks.
E
E
On the MX5 it applies to all the 5 speed boxes from Mk1 through to the Mk3.75 that is up to early 2015.
Not to the cars with the 6 Speed box.
Can you confirm if the shifter mechanism on the 3 wheeler is Morgan specific or Mazda standard.
75-90 gear lube fill until just above the shift rod.
kirkusblog.com
1952 Ford 8N
Re gear lube? It will just stay in the shifter pocket? Also I was thinking of ordering a short shifter, but I see several versions. What would be the correct one? Sorry I didn't mean to Hijack---
Luckily I own a Miata, and have a MIATANET login!!!
http://www.miata.net/garage/trans/everything.html
You can't handle the truth! Fill the shift turret with whatever you want. Bacon grease, motor oil, gear oil, Gibbs Orgasmotronic 2000 Shift Turret Oil, it is nothing more than some balls and springs and a $3 bushing. Replace the bushing early and often and nothing else about the shift turret matters! smile
(Next-Day Edit: The above post was sponsored by my friend's homemade cherry wine, and is NOT entirely true or my official recommendation ... )
A better answer ....
Blah Blah Shift Turret Blah:
1. Replace the bushing early and often. LOOK FOR AND RETRIEVE OLD BUSHING CHIPS FROM INSIDE THE TURRET.
2. The oil really isn't that important, but if the internal seals leak, your turret oil will end up IN the gearbox - so why not used whatever is in the gearbox?
3. If your turret oil keeps going down and it isn't spilling OUT, then your internal seals are leaking. I wouldn't pull a gearbox just because of this - just refill with oil regularly, or just use grease!
4. If you don't seal the shifter boot to the turret (with a good gasket or RTV), then oil can slosh out and make burning smells on the exhaust or make you think you have a leak. If you use RTV, make it THIN ... the shifter lateral detents and springs are IN the shift turret, and the tolerances are fairly tight - you don't want RTV blobs down there.
5. If you are unhappy with your side-side shifter behavior (shifter not springing back to Neutral as strongly as you would like, or you have to slap too hard right to get into 5th, then the issue lies in the turret. This is easily "tuned" without tearing into the box.
kirkusblog.com
1952 Ford 8N
kirkusblog.com
1952 Ford 8N
Thanks Draggin. Ummm cherry wine!
