1 members (Plus Four Guy), 211 guests, and 36 robots.
+8Rich 102
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
Kurt I had a replacement ECU a year ago on my July 2013 car. I think it runs better with the new one. I've never experienced pinking nor do I have the cooling fan.
Tim
I called S$S a few days ago to querie them about new camshafts (about 3/4 race) and the tech told me that I'd need a new ECU also, one that could be programed for the cams. He said if I purchased the cams they would down load the necessary information at S&S. About $400 for new ECU. Guess there is no other way?
Garage 56 now supply a mappable ECU, it'll be worth giving them a call.
https://www.garage56.co.uk/product/m3w-mappable-ecu/
Red Leader drive
Hello,
During this Lockdown period I also installed the Urban Cooling pack on my 2012 Three-Wheeler but I'm still missing the file to upload on the ECU.
Is there anybody that can send me this file by e-mail please?
Thanks a lot
Jef
P964 Offline OP
Hi Jet
I have copy of the file as sent from Morgan a couple of years back.
I can send it to you via PM if you like.
You will need to endure that It is applicable to your car and country.
Using Protune you can look at your current file description, I believe it’s under “comments” to check
If you PM me I will send file and installation instructions
Cheers
Nigel
Jef if you cannot get the correct file you could fit a simple on off switch. You may have to go to a dealer for them to enable the fan automatically.
In my view it's better to have a switch, as the number of times you actually 'need' the fan is pretty limited (unless you live in London perhaps) and the stock setup runs the noisy thing pretty much the entire time otherwise. I simply switch mine on when I am stationary for what feels like too long and haven't had skip-fire since fitting it, including a sweltering day stuck in a jam around Brussels for ages.
I put A Switch on mine
