0 members (),
117
Old Book
Goodwood
Topics49,932
Posts838,511
Posts: 3,727 |
Posts: 2,190 |
I don't know why my underbonnet tackle is so clean. While it's true that I use a damp cloth occasionally, I haven't made a special effort in a 'polish everything' sense.
Lucky man. me, I'm a slave to the 'toothbrush and Solvol Autosol' school!!  G
GLLHG
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
Another 72 hours on and the level is holding. There is a tiny damp patch on the newspaper underneath but no discernable drop in the level. The temperature in the garage tonight was -1.9degC. After an hour with the fan heater on full, the best I could get was 2.0degC, although the pit is a balmy 5.0degC. It doesn't look like I'll be doing much in there this weekend...........
Posts: 2,190 |
Dave, Come to sunny South Wales. Garage temp at 02100hrs ( despite Salamander) -7. Carcoon is, I hope, gonna prove its worth but I tried to do some work there this evening and am now looking for a guy who can braze Monkeys!
regards, G
GLLHG
Posts: 1,597 |
GLLHG/ Dave There is no fun in the garage at the moment. I had great plans to put posters up on the walls. These enlarged from favourite pics in the Morgan 100 book but I fear they will suffer in these conditions. Further I have never failed to get out in "old girl" at least every 2 or 3 days, but no joy lately, last time out New Years eve. My leak has gone completely, hopefully this is not because the water system has frozen. Until I get out on the road again I can't be certain all is well.
Posts: 2,190 |
I had great plans to put posters up on the walls. These enlarged from favourite pics in the Morgan 100 book but I fear they will suffer in these conditions. . I've got the same kinds of 'bits and pieces' on my garage walls. This may be a bit grannies, eggs and inhaling but( subject to size of course) what about laminating the paper copies prior to display? regards, G
GLLHG
Posts: 1,597 |
G You are absolutely right about the lamination, they are a bit on the big size but will soon get damaged if I don't have some protection. Dave Leaks seem to be sorted, took the car out on a run yesterday, 20 miles or so and no coolant observed on paper today. Still getting a bit of sweet smell around the kerbside cat. Perhaps cow dermot from these rural roads. Who knows but will keep sniffing.  Dave
Posts: 2,190 |
The way I approached it with a couple of 'blow-ups which were too big to laminate was to get a roll of some of that self -adhesive transparent covering, cut a piece of hardboard ( which I then varnished to seal it) leaving a 'border" of about 2" using the hardboard as a backing plate mounted the pic and covered with the sticky plastic.
I made sure I left enough to wrap over the edge and it seems to be working OK so far.
I did also try map varnish but it discolours
GLLHG
Posts: 1,597 |
G As soon as I read hardboard backing I liked it. I have some laminate on a roll but just dismissed it because of the challenge of putting it onto my limp posters. I would have been like a big fly on sticky paper. Thanks for that. I will post my pictures when ready Dave
You lot have hijacked my thread with talk of cowpats and sticky backed plastic...........  When I was concoursing, the best cowpat remover (from my immaculately painted wheelarches) were my fingernails.........
