1 members (GLLOQ), 209 guests, and 32 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
Page 4 of 4 1 2 3 4
You should write and tell Morgan so that they can look at that problem and rectify it in future production.
Hey Mo-lks
I have my pedal set still in the "standard" factory position.
But the longer I drive, the more I feel like they must move
one step towards me.
Do you know how many cm/inches this will actually be? sherlock
Pete
in love with life. that's it.
I am AFC (away from car), but as I remember it - about an inch. It was surprisingly easy to do, took twenty minutes.
M3W, now!!!
DocNik, to do so, do I need to crawl into the tunnel? or what is the easiest way to get to the screws?
Difference is only an inch? So that does not give much options with the 3 positions actually :-/
I would say more like 1.5 / 2 inches , but I am away from car as well.
If you look underneath the car alongside where the pedals are you will see a row of rubber grommet blanked off holes and some nuts.
The grommets are your alternative options, the buts what you need to remove to move the pedals.
After removing the nuts I grabbed the pedals through the inspection cover in the engine compartment , which looks vertically down on the pedals.
thanks!
btw: the morgan mechanic from the garage of my trust just told me the pedal box would be moving approx. 4 cm towards me. (1.5 inch).
Right, I forgot about the hatch. All the nuts are under the car. You move the assembly with an arm through the hatch.
M3W, now!!!
excellent. will give it a try!
Comet, One caution--don't move it closer to where you are tempted to use the clutch for a footrest.
Page 4 of 4 1 2 3 4
