6 members (B3MOG, Wouter, John Winn, JohnHarris, Graham, G4FUJ, RedThree),
181
Topics49,901
Posts838,042
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
We prob be at lathwaits car park by virginia water at about 8, will wait there for 10 mins or so. if anybody passing we could convoy up.....
Posts: 42 |
Quick question Were abouts at Blackbush is the caff? Is it at the airport entrance on the A30 or on the industrial estate If I get my act together I may get there
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Quick question Were abouts at Blackbush is the caff? Is it at the airport entrance on the A30 or on the industrial estate If I get my act together I may get there Into the airport carpark and the cafe is on the left according to https://www.thebushecafe.co.uk/
Rise n shine, wrap up warm guys its brass monkeys out there!!!!!
Posts: 1,671 |
Great meeting up this morning guys, fabulous seeing so many M3W's together at Blackbush airfield and new faces too.
All the sheepskins out in abundance as the temperature dropped.
We'll do this again even though it's crisp.
Was good! shame i didn't tighten my drive belt properly.slipping when rog was playing with the z4 in camberly...... made some horrid noises!!!! got home ok though
Posts: 103 |
Posts: 1,671 |
That belt needs to be tight too. We, (Chris Rog & myself) compared belt adjustment & free play at Brooklands last year between our cars & all were really under some tension, mine following a MMC rebuild as apparently factory measure from the ground up datum, where others measure up/down tension
Harley do a tension tester, & M y belt is around 1/4" vertical tension at the centre point.
What do you have?
Was good! shame i didn't tighten my drive belt properly.slipping when rog was playing with the z4 in camberly...... made some horrid noises!!!! got home ok though That didn't quite go to plan, no grip away from the lights and then quickly hit the rev limiter with still no grip. Good to meet up though.
I've tightend it up now about 2mm might go tighten bit more.. had about 40mm when we got home.
