10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 273 guests, and 42 robots.
+8Rich 91
Luddite 50
Posts837,969
#406063 08/11/16 03:39 PM
Shock on Sunday, when operating the windscreen washers on my Plus 4....the fluid poured out from under the dash all over my leg.....you sort of expect the fluid to be on the outside of the car....
Tuftie66
2008 Claret Red +4 Sports
2016 Mazda CX-3, Sport AWD.
tuftie66 #406069 08/11/16 03:47 PM
Not a good look !
I used to get this on my 2009 Sport from new when they used liquorice pipes (maybe they still do) instead of silicon tubing for the washers.
The real worry is that it can spray all over the main instrument PCB and destroy things at considerable expense so it's best to address the issue sooner rather than later.
An easy job with the dash dropped replacing with silicon (think fish tanks) but annoying as they should use something decent at the factory.
Interestingly neither my 1994 or 1999 +8's have done this as it's proper pipes fitted.
tuftie66 #406076 08/11/16 04:03 PM
dmh Offline
I had the same problem when my Roadster was new.
No explanation - but not unknown to MMC and fixed under warrantee.
Good Luck
David H
tuftie66 #406077 08/11/16 04:05 PM
dmh Offline
That should have been warranty I think.
Cheers
David H
tuftie66 #406083 08/11/16 04:19 PM
Forget window washer. Use RainEx. Works for Me!
Button
tuftie66 #406091 08/11/16 04:51 PM
SBM Offline
Have never tried Rain-X but have always promised myself I'll have a play with it soon enough.
tuftie66 #406096 08/11/16 05:05 PM
Just checked out the website, sounds impressive enough
Tuftie66
tuftie66 #406111 08/11/16 05:32 PM
I use RainX.
Works ok but not in a monsoon!
tuftie66 #406118 08/11/16 05:52 PM
I start with Rain X 20 years ago on the motorbike and still use it .Don't need the washers anymore. umbrella
Stefan
tuftie66 #406288 09/11/16 07:55 AM
Take off the dah replace the mickey mouse tube & t piece. Tie wrap the tubes to the jets.
Oh & use rain ex it works
