Posts837,982
Posts: 766 |
Shock on Sunday, when operating the windscreen washers on my Plus 4....the fluid poured out from under the dash all over my leg.....you sort of expect the fluid to be on the outside of the car....
Tuftie66 2008 Claret Red +4 Sports 2016 Mazda CX-3, Sport AWD.
Posts: 37,474 Likes: 988
Posts: 37,474 Likes: 988 |
Not a good look !
I used to get this on my 2009 Sport from new when they used liquorice pipes (maybe they still do) instead of silicon tubing for the washers.
The real worry is that it can spray all over the main instrument PCB and destroy things at considerable expense so it's best to address the issue sooner rather than later.
An easy job with the dash dropped replacing with silicon (think fish tanks) but annoying as they should use something decent at the factory.
Interestingly neither my 1994 or 1999 +8's have done this as it's proper pipes fitted.
Posts: 638 |
I had the same problem when my Roadster was new.
No explanation - but not unknown to MMC and fixed under warrantee.
Good Luck
David H
Posts: 638 |
That should have been warranty I think.
Cheers
David H
Posts: 1,943 |
Forget window washer. Use RainEx. Works for Me!
Button
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Have never tried Rain-X but have always promised myself I'll have a play with it soon enough.
Posts: 766 |
Just checked out the website, sounds impressive enough
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I use RainX. Works ok but not in a monsoon!
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
I start with Rain X 20 years ago on the motorbike and still use it .Don't need the washers anymore. Stefan
Posts: 27,835 Likes: 759
Posts: 27,835 Likes: 759 |
Take off the dah replace the mickey mouse tube & t piece. Tie wrap the tubes to the jets. Oh & use rain ex it works
