Topics49,901
Posts838,042
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
The Roadster Sport will be priced above the normal Roadster seems logical to me, better equiped & more power
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 1,502 |
the spare wheel on the Roadster Sports is a space-saver wire wheel Oh dear. A space saver spare wheel, on a Morgan. Are you sure? It looks full size on the factory photos. Nigel
Posts: 478 |
Hi Ivo, Treads are not really useless, but you are right about water collection. You have to be careful because these treads are fixed with standard steel coach bolts, so after a while this assembly generates a catalytic phenomenon between the aluminium of the wing and the steel. I reinstalled with the S/S button bolts, plastic washers, nylocs and “Duralac” to avoid catalyse. In addition I used silicone between treads and wing to avoid retaining water. Up to know it works and I am no longer using air gun to dry the water after every washing. Of course it is longer to remove and reinstall treads, because as I didn’t find so small S/S coach bolt, button bolts don’ have square cup, so I have to remove the rubber from the rail, screw each bolt and reinstall rubber, but when you like… Best regards. Daniel.
Thanks Daniel, Another job for my list. (02 +8) I'm getting electrolysis corrosion on both my doors, in both cases by the higher sidescreen mount. I'm not to sure why there and nowhere else. Damp side screens providing the necessary "electrolyte" is my only theory. Door respray + Duralac required soon Brian
Posts: 7,363 |
the spare wheel on the Roadster Sports is a space-saver wire wheel Oh dear. A space saver spare wheel, on a Morgan. Are you sure? It looks full size on the factory photos. Nigel I'm very sure, it was one of the differences pointed out by Matt (Humphries) on the Roadster Sport. It was the definitive car on the Geneva stand so as someone else has pointed out, there are some changes between it and the factory photos. I'm afraid that's about par for MMC. Brian
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 2,190 |
[quote=Aeroman] the spare wheel on the Roadster Sports is a space-saver wire wheel Oh dear. A space saver spare wheel, on a Morgan. Are you sure? It looks full size on the factory photos. Nigel God! is nothing sacred?  G
GLLHG
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
(...)I reinstalled with the S/S button bolts, plastic washers, nylocs and “Duralac” to avoid catalyse. (...) to remove and reinstall treads, (...) remove the rubber from the rail, screw each bolt and reinstall rubber(...) Good point, Daniel. I remember having read about corrosion in this area earlier. How do you remove the rubber from the rail. Is is just "squeezed" in, and does it come out easily? How is it put back in?
 1998 +8 (permanently out of service  )
Posts: 963 |
[quote=Aeroman] the spare wheel on the Roadster Sports is a space-saver wire wheel Oh dear. A space saver spare wheel, on a Morgan. Are you sure? It looks full size on the factory photos. Nigel God! is nothing sacred?  G ...at least, it's a wire wheel
Posts: 2,568 Likes: 98
Posts: 2,568 Likes: 98 |
Thinner wheels are easier to do burn-outs with anyhow...
They do have benefits.
Posts: 2,190 |
They do have benefits. Yeh, but a lot less clever if you're stuck on a mountain road in Mid Wales in late afternoon/evening and the nearest tyre depot ( if open) could well be more than 50 miles away!  Cheers G
GLLHG
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
More money for fewer comforts? Yee Gods....... Noooooooooooo.....................
