6 members (MartO, Ian Wegg, +8Rich, SEG, rossocorsa, bmgermany), 233 guests, and 27 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,047
#41470 09/03/10 08:43 PM
Y
Yuri Offline OP
Y
O yes!Overcharging!,I assemble this car with my own hands and done it Wright (not like MMC).And they telling me its a ground wire,car has been damaged and everything can happened,idiots ,everything can happened if YOU assembling car.I my first conclusion was - bosh smart charging system.Nobody believes... check all wiring once more.IT IS BOSH ECU..
Yuri #41501 10/03/10 12:30 PM
What´s up?
Andreas
+4
109er #41513 10/03/10 06:15 PM
Ivo Offline
TM Photographer of 2011
Yeah... what happened? You sound a bit overcharged hide Nevermind, Yuri. It was stronger than me wink
sunny
1998 +8 (permanently out of service frown )
Ivo #41519 10/03/10 07:01 PM
Yuri is there a problem with the Bosch ECU on your Mog?
Trent #41991 24/03/10 08:57 AM
Y
Yuri Offline OP
Y
Ecu in Morgan is BOSCH 0261209020 it contain so called smart charge system,(on power management it is second plug red-yellow wire.)ECU faulty.Nobody knows this ECU,Iwould disconnect smrt charge signal but cannot find wire On X5 is wire 13 on BMW 745 wire 19 on Morga even factory does not know
