7 members (sewin, RichB, Jensen1960, gomog, JMcL, Rastus, hugo), 175 guests, and 24 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
#424671 24/01/17 08:10 PM
DaveW Offline OP
The most common luggage rack seems to be the 'with side-screen storage' version. It locates onto over-rider brackets with cranked L brackets and a nut & bolt each side. It locates onto the full rear bumper with similar but flat brackets. The T bar fixing is a flattened part of a cross tube which is exactly in line with the spare wheel centre.
Still with me and awake?
But there are other versions. One version, which may be the 'no side-screen storage' version has a cross tube which is well below the spare wheel centre and therefore has a large round stainless 'washer' welded to the cross tube which locates under the T bar. I would like to get a photograph of this version.
Another version has a different fit to over-riders with a vertical tube sprouting from the over-rider brackets. I don't know exactly how these fit, and this is another photograph which I would like to get.
Finally, one version, at the rear, has a 'J' shaped tube which stops the side-screens slipping down & out. Guess what - yep, a photo.
If all else fails I will sort this out at the MOG event.
DaveW #424674 24/01/17 08:41 PM
I had the vertical tube type on my plus 4 Dave, a threaded and tapered spigot sits behind the over rider with a nut on the back and the tube from the rack just pushes onto its taper. Occasionally I had to push it home as the tubes work their way off the taper a bit.
It's good to be able to store the screens but down side is the rack sits quite high as its 'thicker'.
I also turned a thick stainless washer to sit between the threaded T bar and the rack, the polished flat plate marks very easily.
Sorry no pics though.
DaveW #424703 24/01/17 10:01 PM
my humble participation, i hope it help
[disclaimer] i am not the owner of the pic's
4 seaters Vertical
Ladder with side screen
Ladder no sidescreen
DaveW #424706 24/01/17 10:08 PM
DaveW Offline OP
Thanks Chester but none of those are what I'm looking for. It has to be two seater and with a spare wheel.........
Steve's is one of the versions......
DaveW #424709 24/01/17 10:18 PM
Dave just thought.. There's a good pic of mine from Jays or SBM when we were on the caramulo trip, one of the pee stops has a good shot of my rear end.. pantsdown
Maybe they can help as I don't have the pics?
DaveW #424710 24/01/17 10:23 PM
If it works this is non sidescreen but centred on the spare
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
DaveW #424712 24/01/17 10:33 PM
SBM Offline
Dave, PM me your email. I have loads..well, a few, anyway..
DaveW #424714 24/01/17 10:45 PM
I am trying to put a luggage rack on my Roadster with out bumpers or over riders.
Because of the size of the spare tyre and wheel 225.50.16. I need a rack without side screen storage .
Any one have one they don't want ?
Peter.
Aero plus8 50th Anniversary.
DaveW #424720 24/01/17 11:01 PM
Posting Desperado
Posting Desperado
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ. its been a long day . grin2
DaveW #424737 25/01/17 12:34 AM
Dave I just purchased a 2005 Roadster
Need a rack, do you have a recommend place to buy the rack
I am located in Florida
Allan 2005 Roadster
