Morgan Aero 8
8 members (TBM, sewin, RichardV6, planenut, Ruut Bianchi, gaston, Barry13, MDS61), 292 guests, and 49 robots.
John V6 74
+8Rich 68
DaveW 67
9,203 Registered Users
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
Topics48,340
Posts812,971
Members9,203
PPP356
Page 3 of 5 1 2 3 4 5
Goodwood Drifter
Goodwood Drifter
I have starting-cables in the car....always...
but what the hack, I'ts the Max
best thing: women love it even more than men love
Steven
now: +fourLM62
Aeroman #42064 25/03/10 07:28 AM
le Asbo du Bling
le Asbo du Bling
Originally Posted By Aeroman
As we can't use a CTEK conditioner in our garage, it really is an annoying issue and I hope someone can come up with a solution to the problem.
Aeroman, I assume your garage is underground and has lights. If you knew a friendly builder / sparks maybe someone could knock you up a fitting that could be plugged into a light winky
The alternative is you could leave it in my garage which has plenty of power, and if the battery looks like its going flat I'll take it for a run to charge it up. hide
Slowly going green
Aeroman #42412 31/03/10 06:40 PM
Originally Posted By Simon
Porsches are better but they have a similar issue.
We had the same Cobra Tracker fitted to the 911 and the AeroMax, in both cases because the insurance company insisted, and when we are away the 911 will stay charged for at least 5/6 weeks. The only thing that happens is the blipper will no longer operate the central-locking and you have to open it with the key. Then, starting it is not an issue.
The AeroMax will barely start after 7-days or so and I use a portable battery booster, but this will only start it if there is something left in the car battery itself as it does not have sufficient capacity to replace the battery.
As we can't use a CTEK conditioner in our garage, it really is an annoying issue and I hope someone can come up with a solution to the problem. MMC says it is the radio that is causing the problem, but the installer says they are not correct. HELP please!banghead
That's a difficult problem Brian!
And probably beyond my technical knowledge.
That said one thought comes to mind. I have a battery booster (SIP) which can be charged up using a cigarette lighter adapter. I wonder what happens electrically when you connect a fully charged booster like mine to the cigarette lighter via the adapter - will current flow in reverse and charge the car battery?
We need an electronics whizz to answer!
Regards,
Robert
Rbt Aero8 thumbs
In a simple classic car 12v system there's no difference between connecting a charger or conditioner to the battery terminals, or to a ciggy lighter socket. The 12v socket is just an extension of the battery terminals.
But I don't know whether complex electronics make a difference to that, and I would ask the factory - just in case.
Portable easy starters? check the manual that comes with the kit. My gut reaction is that it would work better direct to the battery terminals.
For an interesting variation on this theme try using a trickle charger with the ignition key left in situ - not only does the battery run down even faster ~ 24hr, but using the charger triggers most of the dash lights & the indicators! oops
Very colourful - took ages to work it out. sherlock
PS the Aero was in a secure garage.
My guess is that MMC has not got the interface between the BMW & Morgan electrics sorted viz. the problems with water in the electronics under the dash that stopped all the Morgan components working, but not the BMW ones.
Brian - might it be possible to fit a battery isolator switch after the feed for the tracker?
New joints for old!
orthodoc #42426 31/03/10 08:10 PM
le Asbo du Bling
le Asbo du Bling
Brian,
Do you have lighting in the garage and if so how often is this on? thinking
Not to sure about installing an isolator and the effect of using this before the ECU has had a chance to start shutting down.
Slowly going green
asbojohn #42533 04/04/10 09:53 AM
Thanks Guys for all the helpful advice. The problem is that although we have electricity in our communal garage (and in our downstairs store) the electricity is not charged to individual apartments, but is paid centrally and thus is part of the service charge.
One of the other apartment owners put his Lambo on a battery conditioner plugged into a common point and this provoked a row with one of the other owners over whether he was entitled to do this. We then got a circular from the management company entitled "Electricity Theft"! I think these conditioners cost pence per hour to run, but that's the problem with communal living. frown
Head Office has now been elected to the Management Committee with the sole aim of getting a solution to this problem (at last that's my take!) and I'll let you know how we progress.
In the meantime, we are back later in the month and I know the AeroMax's battery will be completely flat. banghead
Brian
2014 Morgan SP1 (Rocket Red)
Aeroman #42563 05/04/10 07:36 AM
Smile, it confuses them
Why not make a low mobile charger that can fit under the car. Small metal plate with casters, 2-3 batteries on it in parallel, slide it under the car and leave in place, then whip it upstairs once a week and give it a charge. If you do this then watch for Captain Cock-up....
Make certain the terminals cannot contact the car at all.
Place a sign on the car to remind you when you are in a hurry.
Put a multi-meter in line to avoid flattening the pack and killing it.
Secure the batteries to the plate well to avoid risk of spill.
I used to do this for the race car many years ago as battery trucks were out of my budget in those days.
Alistair #42571 05/04/10 10:32 AM
Thanks Alistair for the suggestion, but not sure how practical it is when we spend time overseas and need to keep the car charged for our return. woohoo
Also, not sure what Head Office would think about a mobile charger with casters running across her oak floor. shocked2
Brian
Aeroman #42582 05/04/10 12:20 PM
le Asbo du Bling
le Asbo du Bling
Brian,
These thing seem to work on the same principle as calculators so should work indoors if the garage is illuminated. Might be worth a go.
solar chargers
I've looked at the charger supplied with my aero and this has a rate of 0.7- 1.25amp. So this may provide you with enough juice if you can place it under a light and the lights are on 24/7.
Slowly going green
