Posts837,978
Posts: 78 |
Hi Grissly from Dubai again, does anyone have the wheel alignment specs.for my car?
Thanks in anticipation
Volvo XC60 x2 Volvo C30 2010 Roadster 2001 Triumph Thunderbird
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
Track is 3degs from memory but it's all in the hand book .
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I think there are 3 different aspects of front wheel alignment
Initially there are the two alignments which are set by the angles of the frame front in the chassis, so in theory not really adjustable BUT the post 2008 system does allow a very small amount of adjustment of the camber
So there is castor. This used to be 2 Deg , but is now 4 (from memory) and is the inclination of the king pin (in a fore and aft plane)
Then follows camber. This can be anything from 2 Deg negative , neutral , or 2 degrees positive. (this is measured at 90 deg to fore and aft) Use whatever is in the handbook.
Lastly there is toe-in/out this is adjusted by the track rod ends. This can be set to owners preference, BUT use the handbook figure as starting point.
Some leeway is permissible but try to get the reading the same on each side.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Wasn't castor 4 degrees, now 6 Andy?
