2 members (+8Rich, TeddyAds), 218 guests, and 29 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#429733 15/02/17 06:07 PM
Nevbag Offline OP
Can anyone help with info regarding wire wheels please? I would like to know how to measure the wheels/hubs to compare s/h wheels with my own. I have 60 spoke 15 inch wires on my 1961 +4 and they have been knocked about a bit. Can anyone explain which part is 42mm and which part is curly?
I am currently looking at a set taken off a 1990 4/4 and unsure if they will fit.
Nev
Nevbag #429751 15/02/17 07:42 PM
Nevbag Offline OP
A bit of research tells me that I should measure the hubs accross the splines, 62mm in my case. Still don't know which bit is curly though.
Nev.
Nevbag #429756 15/02/17 08:02 PM
SBM Offline
No, I'm not sure what is meant by the term 'curly'. Maybe the inner flange? These guys supply the current range, and there's a lot of info on the site. Or maybe give them a call?
MWS
Nevbag #429783 15/02/17 10:49 PM
Ray Offline
The later wheels were 72 spoke, but the splines should be the same. PS no idea what the curly bit is.
Ray #429785 15/02/17 11:02 PM
JCK Offline
My 59 plus 4 has later 72 spoke chrome wires. It was dispatched from the works with wires, presumably 60 spoke painted.
JCK
1960 Plus 4 Roadster
Nevbag #429788 15/02/17 11:17 PM
I would imagine the curly bit refers to the shape of the centre hub, often an S shape , but not sure which spec you need.
Nevbag #429811 16/02/17 07:46 AM
I don't think there was any difference in the Rudge type splined hubs used by Morgan. The stub axle sizes changed, but that doesn't affect the wheel hubs.
I reckon a set of modern 72-spoke wheels will be a direct replacement for a set of 60-spoke jobs - always assuming that the rim widths are similar.
I believe 1961 +4s would have had 5" rims, so the only ting that might cause an issue would be if the '91 car was a 'wideline' with 5.5" rims - and the balance of probabilities suggests probably not.
Nevbag #429823 16/02/17 08:33 AM
Nevbag Offline OP
The original 60 spokes are fitted with 5.60 x 15 tyres and the 1990 72 spokes ones I am considering buying have 165/80 x 15 which I think means the rims are the same width.
Am I right?
Nev.
Nevbag #429824 16/02/17 08:35 AM
You need the "J" number from the wheel rim.
Nevbag #430178 17/02/17 03:39 PM
As said before MWS should be able to help.
There should be some help here as well
http://www.gomog.com/allmorgan/wheelsindex.htm
