3 members (TalkMorgan, verysideways, IcePack), 333 guests, and 34 robots.
+8Rich 95
John V6 52
Posts838,014
rockabilly john
#43068 15/04/10 09:07 AM
WOX9 Offline OP
Filled up with fuel, went back to start my T16 engined +4, engine turned over fine a number of times, but noticed no sound from fuel pumps. Left it for 5 mins it then started OK. Any ideas of the problem (Did all the normal things - kicked the tyres, opened the bonnet and looked at the engine, started to look up breakdown number etc. etc)
+4 Jaguar Lazuli Blue - MO6 4 MOG, Morgan Clubsport.
Laser Stratos (sadly sold)
WOX9 #43072 15/04/10 10:14 AM
Couple of possibilities.
Intermittent fuel relay.
Immobiliser, if fitted. I have twice had my '98 spin over on starter at normal speed, but not start. Ignition off. Enable immobiliser for 30 seconds, then off. Starts first turn of key afterwards.
Cheers,
Ahhh,
I should also have said: Good Luck!
and Welcome to the forum!
cheers
Cheers,
Welcome.
I find with my T16 that the same thing that Graham reports sometimes. I also have noticed that if I turn the key to first position & wait for the fuel pump it floods & doesn't start. Mine at least needs to be just turned straight over unlike my other cars & I sometimes forget.
Were are you based WOX9?
John V6 #43143 16/04/10 06:44 AM
Interesting, I've not had the flooding problem John (errr, yet!).
WOX9 Offline OP
Thanks all, sounds like faulty relay, new one on its way.
