1 members (New Zealand), 129 guests, and 16 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
AlexCreasey
DaveW Offline OP
Originally Posted By milligoon
Be interesting to see if the bobbins suffer advanced heat damage with the trapped reflected heat.
Nope. Had them on my Roadster for seven years and no problem.
That's good news then dave
Mark - No Longer driving
DaveW Offline OP
Yes, those bobbins last well because they are under compression and the whole thing is quite rigid.
What's more interesting is that those aluminium skids fill up with grit.
DaveW Offline OP
Post Photobucket reboot from 21/02/2017:
Today I've been applying some extra Tectyl 506 under the front wings & running boards, ready for the spring.I also wanted to refit the long plate bracket on the nearside, which holds the running board in place, because it wasn't quite straight...........see below:
So I removed it - held by three setscrews and two self tapping screws. They all came out easily. I trimmed the edge, cleaned the surfaces and refitted, after applying Waxoyl on both sides.
On the offside I wanted to apply Tectyl properly, so the exhaust had to come off. While I had access I thought I'd remove the bracket on this side. Interestingly, both screws had sheared and were only held in place by the underseal. These are quite thin coarse threaded screws, and a couple had sheared on Bumble when I did the same job. Although it's tempting to attempt to re-drill the hole, a screw stub in wood is never going to end well, and reasonably thin replacement screws do go in down the side of the broken screw. It's also a good chance to add a neoprene seal at the front to stop water and mud getting under the bracket.
Below: This shows the offside bracket after replacement, and the neoprene plug at the front. I also added some heat resistant weave to the fuel pipes, because they are very close to the silencer. I did this job on my two previous Morgans.
I also cleaned up the brackets, which were already a bit scabby..............
The final image is not available!
