4 members (+8Rich, B3MOG, Liam1961, Haggispeed), 276 guests, and 33 robots.
+8Rich 92
John V6 49
Posts837,986
JamesB #429497 14/02/17 04:10 PM
JamesB Offline OP
I'll check the drive belt's tension. I did loosen it slightly over the factory setting....but the sound is new after quite a number of miles since the retensioning.
I do have a GoPro and have used it to post a drive in the M3W and used it diagnostically on my airplane to confirm what the main gear doors were doing when they were supposed to be closed. It's a possibility, but I'm not expecting enough movement to see anything.
As I said, I can grab the roll bars and rock the M3W--no sound. Just when I take my foot off the accelerator and the weight shifts forward. Drive belt seems like a possibility.
Speed #429566 14/02/17 08:13 PM
Originally Posted By Speed
Originally Posted By greenteagod
One thing that might be beneficial is picking up a gopro. You can stick them at various points on/in the vehicle. Point them at places that may be suspect, and get em closer to the source of the sound, until you narrow it down.
you do seem pretty damn clued up on the machines, have you owned one before?
LMAO
I thought you would spot this!!
Oh I knew he would. If I can do my part to make a troll happy in his twilight years, well who am I to begrudge him as much. <3
JamesB #429609 15/02/17 12:02 AM
Possibly a squeek from the accelerator pedal?
I had an irritating squeek on my Plus8 organ pedal setup, cured with lubricant.
Different setup to yours but worth a check.
JamesB #429630 15/02/17 08:34 AM
it certainly sounds like an on and off load problem, drive belts or as sospan states have a look at the pedals, or get someone to rev it while you can look at front end and try to hone in a bit then work down the car listening, but if only happening when driving it does sound like belt/drive set up or loose mounts somewhere
Superdry
76 Fizzy
JamesB #429645 15/02/17 09:53 AM
The drive belt is the usual culprit. If you can stick your phone down there and take a picture of the sprocket that isn't covered by the belt then do it. If it is worn and shiny and there is black dust everywhere then you have found the problem. Once the belt blows by the hard anodized surface then it hits the softer aluminum and eats it like butter.
If it still looks OK then adjust the tension. I have found that all it takes is hitting a pothole at speed to mess it up.
JamesB #429657 15/02/17 11:17 AM
Possible candidate for the Supermax sprocket modification?
JamesB #429705 15/02/17 05:04 PM
JamesB Offline OP
Thanks. I don't think it's the pedal.
- When the engine is off, you can move the pedal - no sound.
- The sound seems to come from in front or underneath.
When we can get some dry weather around here, will investigate further.
JamesB #429707 15/02/17 05:14 PM
Mine barks squeaks, and shudders. I know my dealer adjusted the centering of my rear wheel and my belt tension. I should check mine against what people are doing here.
kirkusblog.com
1952 Ford 8N
JamesB #429761 15/02/17 08:08 PM
Check the rubber at the front of the bonnet by the cowel where it touches the front of the body, if it's missing it will squeak like this, check the cap screws under the bonnet that secure the body, again these can model slightly loose and allow the body to move. Try fdriving it with the bonnet off, you might get a clue. Had all the above, all quiet now
JamesB #429766 15/02/17 08:25 PM
Gee, I thought it was designed to squeak and rattle
